How to remove the front end loader on my NH 1920?
icesage
I'm trying to figure out how to safely remove the front- end loader from my NH 1920 tractor. If anyone has a step-by-step guide or some tips on how to do this, I'd really appreciate your help.
Okay, here's what I think you should do, drop the bucket to the ground, pull those hydraulic cylinders all the way back in, and then unhook the hydraulic lines but don't forget to mark them first so you know where they go later! After that, take out those loader pins where it connects to the tractor. You might need a hand or a jack to hold things up since it might be a bit heavy.
You'll want to start by lowering the loader to the ground and disconnecting any hydraulic lines, making sure to relieve pressure first. Then unbolt the mounting brackets from the frame, having a friend or a jack to support the loader helps a lot. Once it's loose, you can carefully back the tractor away or lift the loader off slowly
Additionally, it's a good idea to have someone help you or use a hoist since it can get heavy. Don't forget to review specific pin locations and hydraulic pressure relief steps before diving in.
