Slew system clunking how do you differentiate normal play from a problem
Trailhead
While I was moving dirt with my NH tractor,
I noticed a clunk in the slew and wasn’t sure if it was just some typical slack or if it needed my attention.
Let’s share some quick checks, feel tests, and tips to help figure out the difference.
Mine started acting up right after a long day of moving dirt, and I almost shut everything down, fearing the worst. Turned out it was just some slack, but I had to guess first. It'd be great to have a few quick checks to distinguish between normal noises and actual issues.
I had a similar thump on my NH when I swung too fast and almost leapt out of my seat.
I wasted hours chasing down nothing. Sharing some quick tips to differentiate between harmless clunks
and serious problems would really help avoid a lot of frustration.
@Trailhead The best way to tell is to get the weight off the system. Use your stabilizers and loader to lift the machine slightly, then extend the boom halfway and have someone give it a firm shake from the side
If you see the slew post lifting or shifting more than a fraction of an inch at the pins, your bushings are likely shot. if it’s just a noise with no visible movement, it might just be dry
That’s a great, easy way to check, clear, practical, and straight from real experience
