reddzoom_45
- Sep 21, 2025
- 2
My T6.180 has an ongoing hydraulic issue.. It works fine cold, but once it heats up, the hydraulic pressure and flow drop noticeably. The dash throws a P2098 code, which self-clears after a minute or two. I replaced the coil on the dump valve, but that didn't help.
The dealer checked it a couple of months back and said the hydraulics were in spec, but the problem persists. Could this be internal wear, causing an issue only when the oil is hot and thin? Any ideas on what's causing this specific code and the hydraulic performance drop? Any advice would be a big help!!
