New Holland Lx 665 Turbo starting issue
JDY
I was driving my NH Lx 665 Turbo with no issue, finished up and parked it on a slight incline, I came back an hour later and noticed it had rolled back about 10 feet. Now when I try to start it it just gives me a flashing stop light and the engine won't turn over. Not sure if there is a safety lockout or something on this machine but I am at a loss. Anyone have this issue before?
Thanks
J
It sounds like you might be facing a safety lockout, especially if the incline caused a shift in position.
Try looking at the park brake sensor or the neutral safety switch.
The flashing stop light usually means a safety feature has been activated. You might be dealing with an issue related to the neutral or park switch, or possibly the park brake sensor. I’d recommend checking those first
@JDY it probably rolled because it popped out of its neutral detent
NH skids have a safety switch that prevents starting if the drive levers aren't perfectly centered. try firmly cycling the drive sticks back and forth and make sure they are locked in the neutral position before turning the key
