tractor joe
Member
- Sep 26, 2025
- 9
This is my bro’s tractor, the engineering on the clutch pedal assembly is an absolute joke. At only 405 hours, a cheap clip failed on the cable connection pin, wearing the pin down and dumping the clutch spring at his feet. A $90K tractor literally stopped working because of a 10 cent part.
He’s replaced the clutch pin with a basic bolt and locknut for a permanent fix, but now the plastic clip that holds the cable in the main bracket has also disintegrated.
The dealership won't sell that small clip separately, it's a full cable assembly purchase only.
Does anyone know where to find a suitable replacement C clip? He's got the cable secured with baling wire right now just to be able to use the tractor. The cost cutting here is unbelievable!
