Wondering which New Holland model is best for beginner farmers?
Alan
Administrator
Staff member
Admin
Moderator
If you’ve just stepped into the farming world and are checking out New Holland equipment, it can be a bit much to handle. From compact tractors to mid-range workhorses, each has its own strengths.
For someone just starting out, what model would you suggest? I’d really like to hear your experiences and why that machine makes sense for a newbie getting their feet wet in the field.
I cut my teeth on a New Holland Boomer 24. It was small and easy to control, which made it great for a newbie like me.
Started farming with a Workmaster 35. It was strong enough to mow and do some light loading, but not too much that I got stressed out. It was a good first tractor and I learned a lot.
When I first started, I chose a New Holland TC30. My land was not big, only a few acres. But I needed to mow, haul stuff, and till lightly. The TC30 was easy to care for and not too big. It helped me feel confident enough to get bigger stuff later.
The TC33D with hydra-static transmission would be a great 1st tractor, small, nimble. You can run the rear tires right up close to the fence posts while using a 5' brush cutter to mow. The hydro tranny is perfect for the roto tiller or when you want to get up close to something (inching up).
    1.3 MB
That TC33D setup looks great with the Brush Crusher in front and the cutter in the back. The hydro makes it easy to maneuver closely, too. Yeah, it's a solid choice for a first tractor. Thanks for sharing the photo.
