Telehandler stability on uneven ground
grease4ndgrow
When it comes to handling a telehandler on those tricky slopes or bumpy terrain, what’s your secret sauce for keeping everything balanced? I’d love to hear your tips, tricks, or even that must-have safety gear that you can't live without. Let’s swap stories and share what works best out there.
Dealing with a telehandler on uneven ground is all about respect for the machine and the terrain. My approach isn't really a secret but definitely crucial. I slow everything down. Like crawl, keep the load low and tucked in when on a slope, and always drive straight up or down the fall line. Avoid traversing slopes if you can. You must definitely check your tire pressure as it massively affects stability and footprint. Also always deploy and properly set the outriggers when lifting near capacity or reach limits, especially on soft or uneven ground. It's your best insurance. What model are you running? Knowing your specific load chart is absolutely non-negotiable!
Absolutely! Those are some solid points. I’d also recommend keeping an eye on the boom angle sensors and frame level indicators. It’s easy to overlook, but even tiny mistakes there can quickly mess with your safe lift calculations.
