Common engine overheating causes on New Holland machines and how you fix them
Rivertrail
If you’ve been operating these machines for a while, you know how often the engines can hit that alarming red zone.
So, let’s swap some quick checks, field fixes, and smart tricks to keep those engines cool
and steer clear of that dreaded hot engine panic during your shift.
After that one summer when my engine was flirting with the red zone every afternoon, I made it a habit to check the coolant levels, clean the radiator, and keep an eye on the fan clutch. Just a few minutes of prep can save you a world of stress when the heat really kicks in.
When my old loader almost cooked itself, I learned a valuable lesson,
always check the coolant, watch for blocked airflow, and make sure the fan clutch isn’t frozen.
These little tricks can keep your engine cool and save your shift from turning into a fiery disaster.
I've seen too many engines struggle through long shifts. My go-to routine?
Keep an eye on the temperatures, clear any debris off the radiator, and give the fans a little wiggle test before diving into heavy work.
It helps keep the panic at bay and the machine running smoothly.
