Removing remote control valve and lift control valve.
Fredneck
Member
Can I remove both the remote control valve and the lift control valve on a workmaster 35 and pipe directly from the pump into the three point lift fitting?
Thanks - Fred
Thanks - Fred
The answer is yes. I I just removed the remote control valve, joystick with cables and lift control valve. With a little modification to the plumbing, got everything working just fine now and no unnecessary hydraulic system components needed have been removed. And now available for sale at half the CNH prices. 49 hours on the tractor when hydraulic modifications were done. All removed compoents are as new.
Didn't need those hydraulic components. Tractor was delivered without a loader, so I had no use for those extra hydraulics.
Using the tractor for landscaping. Box blade, terracing blade, drag harrow and such.
