Inspecting bucket pins and linkage before they get sloppy
While you’re greasing up your New Holland loader, you might notice a bit more play than you did last season. To prevent those annoying clunks and oval holes from developing, what quick checks or simple tricks do you use to spot potential pin and linkage problems early on?
I take the bucket and shake it side to side with the loader lifted. If there’s noticeable movement, it means the pins are getting loose. It’s best to catch it early then you’re just swapping out bushings instead of the entire pin assembly.
Pay attention to any clicking or clunking sounds when you move the loader through its full range. Noise indicates wear. Also, keep an eye out for uneven movement that’s a clear sign that something is loose up there.
While greasing, check for shiny spots on the pins.
If you notice wear patterns or if the grease fitting is tough to pump, it's likely the bushing is shot.
It’s much easier to address it now than once everything's completely worn out.
I use a pry bar to test for play at each pin. It shouldn’t move more than about an eighth of an inch. If it does, it’s time to order parts before things get worse.
