Front Loader drift normal or fixable?
Blueandbruised
Active member
Is your loader taking its sweet time to stay up when you raise it? Let’s dive into a few possibilities, like those pesky hydraulic valve problems, worn-out cylinder seals, and some quick fixes that actually hold up. Trust me, we’ve all been there, and it can be a real hassle.
Oh yeah, I had the same kind of thing happen to mine before. It ended up being a cylinder seal that was leaking. Once I swapped it out, the loader worked like it's supposed to again.
Also, see if there's any air in the hydraulic lines that can make the lift slow and the pressure uneven. Bleeding them might do the trick.
Also check for a clogged hydraulic filter or contaminated fluid, both can restrict flow and slow response. A weak pump could also be the culprit if pressure drops under load.
